en.wikipedia.org/...
VM Motori Automotive Applications
[edit] 3 Cylinder
[edit] R 315 SOHC
1.5 L (1493 cc) I3, with a single overhead camshaft, four valves-per-cylinder, and common-rail direct fuel injection.
Applications:
* Hyundai Accent (power: 90 hp (60 kW); torque: 133 ft•lbf (180 N m))
* Hyundai Matrix (power: 90 hp (60 kW); torque: 133 ft•lbf (180 N m))
* Hyundai Getz (power: 90 hp (60 kW); torque: 133 ft•lbf (180 N m))
[edit] 4 Cylinder
[edit] 425 OHV
2.5 L (2499 cc) I4, with two (pushrod-actuated) valves-per-cylinder and indirect fuel injection.
Applications:
* 1990–1999 Rover 800 (power: 118 bhp, latterly 120 bhp; torque: 197 ft•lbf)
* 1992–2000 Plymouth Voyager (power: 114 hp (85 kW); torque: 193 ft•lbf (262 N m))
* 1994–2001 Jeep Cherokee (power: 118 hp (88 kW) @ 4000 rpm; torque: 221 ft•lbf (300 N m) @ 2000 rpm)
* 1995–1998 Jeep Grand Cherokee (power: 114 hp (85 kW); torque: 221 ft•lbf (300 N m))
* 1996–2000 GAZ GAZelle (power: 101 hp (75 kW); torque: 171 ft•lbf (232 N m))
* 1997–2000 UAZ 3160 (power: 101 hp (75 kW); torque: 171 ft•lbf (232 N m))
* 1999–2000 Dodge Dakota (power: 114 hp (85 kW); torque: 221 ft•lbf (300 N m))
This engine was also used in some early Toyota Landcruisers & hilux, and Opel Fronteras. It received bad press during the late 1990s for problems with the timing chain, which often broke with catastrophic consequences.[citation needed] This was improved from 1998 with a double chain design. Also had problems with corrosion in the 4 individual cylinder heads, which was not solved until model change in 2000.[citation needed] Temperature problems were also observed, taking into account that this motor was designed to be a marine motor, so the Cherokee TD suffers from overheating and some individual cylinder head can break.[citation needed]
[edit] R 425 OHV
425 OHV fitted with direct fuel injection for cleaner emissions.
Applications:
[edit] RA 420 SOHC
2.0 L (1991 cc) I4, with four valves-per-cylinder and common-rail direct fuel injection.
Applications:
* Hyundai Elantra (power: 111 hp (83 kW); torque: 184 ft•lbf (250 N m))
* Hyundai Santa Fe (power: 111 hp (83 kW); torque: 184 ft•lbf (250 N m))
* Hyundai Trajet (power: 111 hp (83 kW); torque: 184 ft•lbf (250 N m))
* 2007 - Chevrolet Lacetti (121 HP, 210 nm torque), Epica and Captiva (150 HP, 250 nm torque, under the new engine code Z 20 S1.
[edit] R 425 DOHC
2.5 L (2499 cc) I4, with four valves-per-cylinder and common-rail direct fuel injection.
Applications:
* 2001–present Chrysler Voyager (power: 141 hp (105 kW); torque: 251 ft•lbf (340 N m))
* 2002–2004 Jeep Cherokee (power: 141 hp (105 kW); torque: 251 ft•lbf (340 N m))
* LDV Maxus ldv.com/...
A de-rated version of this engine putting out 100 hp was chosen in 2006 to power the new generation of the iconic London Taxi
[edit] R 428 DOHC
R 425 DOHC enlarged to 2.8 L (2766 cc) displacement.
Applications:
* 2001–present Chrysler Voyager (power: 148 hp (110 kW); torque: 251 ft•lbf (340 N m))
* 2002–present Jeep Cherokee/Liberty (power: 160 hp (120 kW); torque: 295 ft•lbf (400 N m))
* 2004–present BMC Megastar (power: 127 hp (95 kW); torque: 184 ft•lbf (250 N m))
[edit] 5 Cylinder
[edit] 531 OHV
Essentially a 425 OHV with an extra cylinder. 3.1 L (3125 cc) I5, with two (pushrod-actuated) valves-per-cylinder and indirect fuel injection.
Applications:
* 1999–2001 Jeep Grand Cherokee (power: 138 hp (103 kW); torque: 283 ft•lbf (384 N m))
[edit] R 531 OHV
531 OHV fitted with direct fuel injection.
Applications:
[edit] 6 Cylinder
[edit] 638 OHV
Essentially a 531 OHV with an extra cylinder. 3.8 L (3749 cc) I6, with two (pushrod-actuated) valves-per-cylinder and indirect fuel injection.
Applications:
* 1995–1999 Asia Motors Combi (power: 135 hp (101 kW); torque: 236 ft•lbf (320 N m))
* 1995–2000 Bucher-Guyer Duro (power: 148 hp (110 kW); torque: 251 ft•lbf (340 N m))
* 1999 Bering trucks (power: 116 hp (87 kW); torque: 295 ft•lbf (400 N m))
[edit] R 638 OHV
638 OHV fitted with direct fuel injection.
Applications:
[edit] D 642 OHV
Essentially an R 638 OHV enlarged to 4.2 L (4164 cc) displacement. It was the first VM Motori engine to feature direct fuel injection.
Applications:
* 2001–2002 Bucher-Guyer Duro (power: 158 hp (118 kW); torque: 295 ft•lbf (400 N m))
[edit] RA 630 DOHC
A 3.0 L (2987 cc) double overhead camshaft V6, featuring four valves-per-cylinder and common-rail direct fuel injection.
Applications:
* Estimated available power: 247 hp (184 kW); torque: 369 ft•lbf (500 N m)
[edit] See also
[edit] Other vehicles which used VM Motori engines in some models
* Alfa Romeo Giulietta
* Alfa Romeo Alfetta
* Alfa Romeo 6
* Alfa Romeo 90
* Alfa Romeo 75
* Alfa Romeo 164
* Alfa Romeo 33
* Alfa Romeo 155
* Ford Scorpio
* Opel Frontera
* Range Rover Turbo D
* Rover SD1 (Rover 2400 SD Turbo)
* Rover 800
* Toyota Hilux (2.4D)
* Toyota Land Cruiser
